I got this info from the Bulb Thread2007+ Sedan & Coupe - 3.5SE w/Premium PackageLow Beam - HID D2RHigh Beam - H9Foglights - H11
Glove box - 158Map light - 578Dome light - 3175 Step/Courtesy light - 158Trunk/Cargo area - 158License Plate - 2825(194)
I've been buying LED bulbs from ebay using these bulb #s and so far the dome light works. The Map light #578 I only found 1 on ebay, bought it and it turned out to be the double ended one, not the one you insert. http://cgi.ebay.com/ebaymotors...&rd=1
so I just compared this info with the manual and a lot of them are not matching up, I'm kinda confused. Can someone pls explain the diff between this list and the manual ? In the manual it says the Glove box light is 658 @ 3.4V while the Step light is 194. But in the above info, they use the same bulb. The trunk light code (158) does match.
