okinawa drift »
https://forums.nicoclub.com/okinawa-drift-u62058.html
Tue May 04, 2010 9:45 pm
ok so i took my friends stock sr for a spin the other day, at WOT aka full boost, his car seems to actually pull me back into the seat compared to my car
my sr specs:
S13 head, s14 bottom end
Apexi headgasket
S14 t28
Toda Racing Cams 264's
Toda Adjustable Cam Gears
Toda Valve Springs
Tomei Rocker Arm Stoppers
Denso Iridium Plugs
ACT Prolight Flywheel
Stage 1 spec clutch
my friends sr has a stage 3 clutch, but i don't see that making a difference since my clutch isn't slipping or anything like that..
i checked for vaccum leaks, couldn't find any. when i give it full throttle it it builds up to around 6psi it looks like, and i know i don't have a vaccum leak.. my question is.. do my cams need to be timed in order for them to even add power? i swear full throttle feels alot better on my friends stock sr than mine, haha..
when im at WOT, my a/f reads around 11.5, and doesn't stutter or anything.. so i know timing has to be right on or close
