so, what steps should i take to get them to seat? I was going to have them replaced and have to whole engine checked for any other problemsboro drift wrote:With it smoking under acceleration, I'm gonna say you got some rings that didn't seat.
thanks for the info. I just removed the intake manifold and found oil in the manifold and above the valves. There is actually a puddle of oil above all the intake valves.boro drift wrote:Re-hone the block, and a new set of rings.
Bore prep is the secret to seating piston rings. Mostly, CLEANLINESS!
I use Zep 'Power House' cleaner on the bores with white paper towels. Spray and rub the bores untill the paper towels come out clean.
Once the bores are clean, oil the ring lands,(I pour a little oil on the dome of the piston and smear it to the sides to let the oil drape over the rings and lands), and install the pistons.
Your next step is to perform a leak-down test. That will tell you where the problem lies.Madngineer wrote:
Do you think i need both seals and rings? Any input would help. I think its strange that rings and seals could go at the same time.
thanks steve
Sounds like bad valve guides then. Remove one of the valve springs, pull the valve out about an inch or so, see if it has any side to side movement. There should be barley enough to feel by hand.Madngineer wrote:Too Late, I already removed the head. I inspected the rings and cylinder walls and they seem to be in great shape. The walls are still crosshatched. The cylinders were full of oil, enough to fill the piston dome. It seems my problem lies in the head. I might have bad valve seals or bad guides.
