DevilMB3017 »
https://forums.nicoclub.com/devilmb3017-u47101.html
Wed Mar 26, 2008 3:39 am
With stock bore pistons and V2 cams, my emissions went up a little bit.
You can try running cheaper/lower octane gas and messing with the timing to pass emissions, here in Jersey at least.
However, I believe that Crower says V3 cams need ECU tune to fix - so I'd recommend the SAFC or Emange and you'll be set
