Built KADE eating oil. whats wrong?
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
alright so whats the deal with my built kade eating oil? i use 10w-30 ams racing oil. drove the car for about 6000 miles and then did the oil change. when i drain out the oil it look like it ate up about 1 quart of oil. couple of days before the oil change i check my oil and it was reading about half on the dip stick.
my motor runs good and its n/a not turbocharged since i dont have a job. i havent had time to do the compression test yet so when i do i will let you guys/gals know about it.
i check all around my motor and so far i see no oil leak, only little bit of oil leak around my transmission.
i will keep you guys updated whenever i have time to jack up the car and check it out.
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Are you emitting blue smoke from your muffler?
240sxvaj
mattblancarte wrote:Are you emitting blue smoke from your muffler?
no, no colorful smokes.
everything runs good on the car. no lose in power or anything bad.
