Built KA problem. car wont start with a/c on
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
my car has this problem eversince i got the motor built.
Problem: i cant start up my car with my a/c on. it would turn over and all but then wont start. i would have to turn off my a/c and then start up my car and then it would start right up. this happen on hott or cold days.
i remember when my motor use to be stock (stock internals) and when i had the a/c turn on it would start right up.
what could be wrong?
motoman399
Car: 98' wrecked (RHD coming soon) 240
the only thing i can think is check the wiring harness out of the firewall that runs over the driver fender well... my wheels scraped that once.
xX RB Xx
Car: SE3P, FC3S, FC3C.
motoman399 wrote:the only thing i can think is check the wiring harness out of the firewall that runs over the driver fender well... my wheels scraped that once.
yeah mine did that once... except i tore right through the harness..
but i dont think that is his problem
motoman399
ya i went through some wires and when i turned on my headlights the fan would come on lol. i dont see what else his problem would be. cause building the engine has nothing to do with either the a/c or the starting.
xX RB Xx
i went through the fuel pump, headlights, and 2 other ones i cant remember
xX RB Xx
the only thing i can think of is that the grounds arent tight or you battery is low and you dont have enough power to start.
240sxvaj
my volts for my afc neo read around 13.3 and up.
all my ground wire are pretty tight to the point where i was scared i might over torque it and break the screw.
as for my battery its been recharged from autozone and i used it for awhile now with no problem
i was suprise that it wouldnt start on me when my a/c is on.
anyone here had this problem yet? what caused it to not start?
