Built KA: HG and O-ring Question
MaxType 240
Car: 1995 S14
The block is already checked/tanked, bored, decked, etc and I remembered about o-ringing late in the game.
I'm keeping my existing turbo/fuel setup and I'm going to go w/ an OEM HG. (Head, forged pistons/rods make for one overbuilt engine for now)... If detonation occurs, I'd rather have the HG fail first then the expensive goodies. I'm gonna invest in ARP main/head studs to ensure the HG is the weakest link. With my line of thought, should I o-ring the OEM HG?
The shop will be assembling my head 1st week of Jan (3-angle valve job, Ferrea valves, springs, retainers). I should have all the parts and pieces mid-Jan and I'm gonna let them assemble the entire thing.
Your experiences and thoughts are appreciated!
Jesse
95_240sx
Car: My baby (car)
Wow, I will clue you in as to why an O-Ring is a BAD idea.
I originally had an o-ringed block and stock HG with stock head bolts. I never had any problem until I toasted a motor for stupid reasons. After the new motor was built I kept the same setup and then blew a HG one night. I then decided to go with ARP's and stock HG, still keeping the o-ring. It just does NOT work, the way the ARP's tighten down isnt the same as the stock HG and it would leak water into the cylinders because it wouldnt bite into the HG. After trying many different combinations, and burning up 4 HG's in the process I finally took a bastard file and filed down the o-ring until it was flush with the deck of the block. I then put in a stock HG with the ARP's and had NO problems....until 26psi where I started lifting the head. I am going to go to ARP's + Cometic for next season as well.
Rick
MaxType 240
Car: 1995 S14
Sorry you had to go through this, it's tough being the leading edge. At least you have the satisfaction of saving others from such despair - thanks for sharing!
Jesse
95_240sx
Car: My baby (car)
Im not telling you not to, just letting you know what has happened to me and you can make a decision from there.
send me an email if you have any questions.
[email protected]
