MaxType 240 »
https://forums.nicoclub.com/maxtype-240-u7345.html
Wed Dec 29, 2004 3:29 pm
Fiznat, I'll be heading your way come May - I'm being stationed in MA (Hanscom AFB), 9 miles from my hometown of Waltham. Might start up a business too
- Valve guides, I'll order them, PM me a part number if you could, thanks! - I've heard of OEM HGs holding super well, that's why I was thinking OEM gasket set. I decided to go w/ the Cometic HG though, so Felpro is an option if the quality is proven on 400-500hp cars.- I've heard very good things about the OEM head/main studs but, like everything else, I'm going to overbuild it from the start.- I've got a new water pump- Fiznat, if you've compiled a complete list for the engine build, could you PM or email it to me? I'm using all the existing turbo, fuel, ign, ECU mgmt for the time being, just need to make sure the all the angles are covered for the engine build.
Naro, I already have a UR Pulley set and Fidanza flywheel on my existing setup. That stuff will transfer over. I have 3 KAs to pick parts from, so stuff like alternators is too easy...
Thanks guys!
Jesse
