It just backfires anytime the boost levels get high enough and it doesn't matter whether I am full throttle or half throttle.. as long as boost builds up, it WILL backfire.
Anyways, here's a picture of my S13
Hmmm, now that I know your choice of spark plug, can I ask why are you running such a cold plug? The BCPR6ES-11s are more than efficient for your application. Colder plugs have been giving me nightmares when it comes to tuning this motor and I live in a very tropical environment. The 7s fouled easier and were causing the car to flame too much. I've never used the 8s as there was no need for the 7s.Leve1One wrote:It started backfiring with BCPR7ES gapped at 0.6mm. Initially I thought that the plugs were the culprit, so the first thing I did was to go for the BCR8ES gapped at 0.6mm. No difference whatsoever. Also, IK22's and PFR7A. Same thing.
