A lot more than you will probably be able to throw at it. It's hard to say since most of the high horsepower SR20DET's use strokers. It could probably handle close to 1000 but you'll be worrying about a myriad of other things before the crankshaft.Nicen96 wrote:Hey nico people i was wanting to ask a few questions about my build i am doing. The first question is how much horse power will the stock crank handle.
None of those are truly power adders but the cams should flow pretty well for 5-600 but the rods I wouldn't test more than 600, if that. Eagle says they are good for 750 but with rods what truly matters is what RPM they are operating at. The stress of 750hp at 2700 RPM is a lot less than 750HP at 9000 RPM.Nicen96 wrote:My build so far, bc 272int 272exh cams, eagle h beam robs, bc valve springs, bc titanium retainers, cometic 1.1mm head gasket, cp pistons 86.50 bore, greddy rocker arm stoppers, jdm valve guides and seals, acl main, rod , tryst bearings, si engineering int and exh valves , and arp main, head and rod bolts. what kind of power can i make with this build. Thanks to any in put.
Jake LeBlanc
