virus77 wrote:1) If im puttin in ross pistons do i need to have to rotating assembly balanced, do normal machine shops do this or just bore and hone, check clearances, etc.
It's not needed but I would highly recommend it. The place I had do it balanced everything individually in 3 hours for $150. For longevity I would get it balanced.
Quote »2) Im not going for arp hardware, but should i change the main and rod bolts to new factory ones or do the old ones work[/quote]The only way to know is to measure them to see if they have stretched or not. I purchased all new oem bolts from a nissan dealer so that's also an option.[/quote]
Quote »3) God damit should i just fork over the extra 7 bills and get rods ( this question is opinion based, I know)[/quote]If I was you, with your hp goals, I would just have the stock ones shot peened (ie, boostdesigns). your motor should be plenty solid to a little over 400hp.
Quote »4) anyone have a recomendation of good pistons, or is Ross a good choice, i was also looking at the other ones ka24de.com offers[/quote]I bought the supertech phosphorus coated pistons and I couldn't be happier. If they're not just as good, they're better than the other options. With the prices all comparable, it's really up to you.
