mikesim »
https://forums.nicoclub.com/mikesim-u15757.html
Thu Jul 13, 2006 9:57 am
here's my setup: greddy fmic, greddy mbc (placed 12" from turbo), hks gt2530 .64 a/r turbo, s-afc II, stock mafs, dsm injectors, 255lph walbro pump, NGK copper BKR7E gapped .028"
this is my problem: when clicked down to .6 bar/8.7psi, boost comes on steady and reaches max at 4,000RPM. but at a larger amount like say .8 or .9 bar/11.6-13psi, boost still comes on steady, but sticks at .6 for a second and builds to fulll boost at nearly 5,500rpm.
i've checked vacuum lines over and over again, finding two unplugged connections, but that's only helped the idle. i've checked the FMIC piping, but all the clamps seem ok, and they've never slipped off.
what i am guessing right now is since we clocked the turbo a bit, and my friend shimmed the wastegate, it's causing it to stick because it looks slightly cocked.
also, people have been telling me the MAFS would max out by 12 or 13 psi on this turbo, but it doesn't. it gets to 88-91%.
any insight on this would be really helpful. thanks.
Mike
