thejewboy wrote:they are kicker 07CVR104 or 07CVR102. they are the same sub but one is 4 ohm and the other is 2 ohm. im gonna buy two of them.
shortmag wrote:you can use either a 1 or 2 channel amp, it doesn't matter. most who have 2 channel amps, run them bridged (meaning they combine the two channels ( Left+ and Right-) to push the most power to the subs.
thejewboy wrote:yep iam new to car audio and thats the best advice ive gotten so far. thanks alot you have no idea how much u just helped me
...Or did he?
With that advice, you may toast your amp.
I'm finding mixed info on those woofers, are they single or dual VC? (I'm finding both, though Kicker.com only lists them as dual VC, so let's assume that.)
BACK TO OHMSDual 2ohm VC's wired in parallel=1 ohm.Dual 2ohm VC wired in series = 4 ohmDual 4ohm in parallel = 2ohmsDual 4ohm in series = 8ohms.
Dual 1ohm (2 subs) loads in parallel = 0.5ohms.Dual 8ohm loads in seriese = 16ohms.
Single channel amp, wired to a 2 ohm load = each channel sees a 2 ohm load.2 channel amp, bridged to a 2 ohm load = each channel sees a 1 ohm load.
So you can see depending on what woofers you buy and how you wire them, you can ultimately have one .5ohm load all the way to one 16 ohm load. Quite the difference.
Bridging your amp to a .5ohm load will either shut it down quick or make it release the magic smoke that makes it work.
Pick the amp you want, see how low it's rated to (4, 2, or 1 ohm) and make each channel operate at it's lowest rated impedence for the most power. Too high of an impedence and you wont produce as much power as you could, though that's not a big deal. Too low and your amp wont work by either shutting down or burning up.
