Building my own manifold
Nicen96
Car: 1996 240sx
Ok I have searched for a long while now and i need to find a place that sells 90s, straight, and 45s in stainless pipe that is 1 1/2 in diameter. Also i need to find the inserts or whatever they are called that when you build a manifold they go through the flange so you can have a smooth air path. Someone told me that they make these. One of my buddy's is building me a custom manifold. Thanks to anyone that can be helpful.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
I believe your talking about mandrel bends. http://store.racing-solutions.org/180deu.html here you go. These people are good to deal with.
Nicen96
Car: 1996 240sx
Thankyou very much CSUPUEBLOTIM. Do they sell a transition piece that will be flush with the exhaust prot opening.
CSUPUEBLOTIM
Nicen96
Car: 1996 240sx
but isnt the exhaust ports an oval shape though and thanks again
CSUPUEBLOTIM
I think typically the angle of the last bends before they go to the turbo flange and cut so it opens up to the size of the turbo flange inlet. This is what I am talking about http://www.dcr62.net/Car%20Pic...1.jpg . All the runners are turned into one and then you weld the turbo flange on.
Nicen96
Car: 1996 240sx
yes i know that but i am talking about when the exhaust runners are welded into the exhaust flange. i need one end of the pipe to be 1 1/2 and the other to be 3 3/4 by 1 1/4 in an oval shape(I think) i dont have a tape measure to be exact, but do you understand what i am saying.
Nicen96
Car: 1996 240sx
anymore help from anyone else would be great help thankyou
CSUPUEBLOTIM
O ya mean to go from oval on the manifold flange to round on the runners...or just get large enough piping to just go around the oval then you wont need to buy transitions.
exhsturbine
Car: 1997 240
http://www.verociousmotorsport...mance
check these guys out. they have lots of cool stuff, merge collectors, mandrel bends, manifold flanges, nearly everything to make your own manifold, plus alot of other things you might get ideas for. good luck
Modified by exhsturbine at 2:46 PM 7/8/2008
Nicen96
Car: 1996 240sx
Thanks alot exhsturbine for the web sit this is a great place. Also if anyone else has any other places to make things easy for me hit me up.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
Nicen96 wrote:Ok I have searched for a long while now and i need to find a place that sells 90s, straight, and 45s in stainless pipe that is 1 1/2 in diameter. Also i need to find the inserts or whatever they are called that when you build a manifold they go through the flange so you can have a smooth air path. Someone told me that they make these. One of my buddy's is building me a custom manifold. Thanks to anyone that can be helpful.
you dont have the technology or the steady hands to pull off a procedure like that........
Nicen96
Car: 1996 240sx
What are you talking about caddylt1. First off i never said that i did or was able to do the work. Second off there is a guy named chris phillips from local 43 pipe fitter from chattanooga that is doing my work and evryone said he is the man for the job(other pipr fitters) so that is who is doing my work. So anyone that will help me figure out my prosesses of what i have to do to make it easier will be great. Thanks Jake LeBlanc
Koshin
Nicen96 wrote:What are you talking about caddylt1. First off i never said that i did or was able to do the work. Second off there is a guy named chris phillips from local 43 pipe fitter from chattanooga that is doing my work and evryone said he is the man for the job(other pipr fitters) so that is who is doing my work. So anyone that will help me figure out my prosesses of what i have to do to make it easier will be great. Thanks Jake LeBlanc
Dude its off Superbad, relax......good luck with the manifold, I am actually wondering whats its gonna look like.
Rich
Nicen96
Car: 1996 240sx
my bad i am sorry. also anymore input on places to order flanges, mercollectors, and pipe from.
exhsturbine
Car: 1997 240
i just thought about it......
http://www.mcmaster.com/
these people sell s***loads of stuff to build. you can get all sorts of different building materials. and pipe inpeticular, whatever OD,ID wall thickness, alloy, length, finish etc.... definately a place to book mark. and they ship fast too.
Nicen96
Car: 1996 240sx
thanks again for this great place anymore places will be greatly appreciated
