building Apexi PowerFC boost controller kit? MAP sensor?
thomasK(austin)
Car: '93 TT Z32, '82 bmw 320i
Im trying to build a kit for my power fc. im buying the apexi solenoid but which MAP sensor can i get that doesnt cost $150. There are other 3-bar map sensors that cost significantly less, like $50. the only thing that can be different is the voltage to pressure ratio that the signal wire sends to the ecu. anyone have any idea if there is another MAP sensor i can use?
Thanksthoams
Joe
GM 3bar sensor should work, anyone confirm?
Carl H
heres a hint, mr2 map sensor .thank me later...
thomasK(austin)
sw20 mr2? does it matter if it is turbo or NA?
thanks in advance!
thomasK(austin)
damn, mr2 map sensors are expensive new.
Carl H
yes sw20, best bet is to find one in a junk yard or steal some ones when they arnt looking...
Imissmyturbo
Car: Car's, Turbo's, sking
how much was the selonoid and where did you get it?
thomasK(austin)
the solenoid was $114 from 9secondracing.com
thomasK(austin)
it is apexi part # 499-X003it is also on racerwheel.com
blk90s13
Carl H wrote:yes sw20, best bet is to find one in a junk yard or steal some ones when they arnt looking...
how much will it run me if you steal one for me ?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Anyone know anyone who has one that works? I Have known a few people that have tried with no luck. A guy at apexi told one of my friends to just get a AVCR and don't bother with PFC boost controler.
