building an l28et
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
ok so im sure ill get an answer from evil soon enough lol
was wondering if building a hybrid n42 block from a 78 with dished pistons and a p90 turbo head with a 2mm head gasket and APR studs would be safely hold 15 psi of boost.
probably with megasquirt and a holset turbo.
crazy idea im toying with. will not reveal till i commit
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
15 lbs fomr a holset...wel depends ont he holset, if it's the hx35 or hy35 or larger thats pushing your luck 15 psi fomr the stock turbo wiht an intercooler yes, maybe even 15 psi from a T3O4E, remember all psi are not created equal, psi is a measure of pressure, lbs/min is a measure of volume
and f course you'll need bigger injectors to go with anything larger than a stock turbo
evildky
06 Nissan 350Z GT
oh and you could go wiht the 1mm gasket wiht the dished pistons
hbpignosePA
90 Volvo 240 (sold)
ok holset was just one option and id def upgrade the fuel injectors.
reason being.
i know where a parts car is for the manifolds head.
have a n42 block
with some machine work rebuild etc id have a pretty nice l motor
evildky
06 Nissan 350Z GT
yup, nothign wrogn with the N42 block, some argue it's stronger thant he F54 and the dished pistosn are the same volume as the turbo, don't forget about the oilpan, oil "T" and oil feel line
kelloggman
Car: 73 240z
hahaha dont forget the turbo dizzy and shaft
evildky
06 Nissan 350Z GT
if he's running megasquirt he can use cop, edis or an n/a distributor, megasquirt gives you infinite options
hbpignosePA
90 Volvo 240 (sold)
ok
well
ill throw it out here.
its going in a 240sx
so MS is probably a definite, reason being is i HAVE the longblock.
can get the turbo parts (everything but the turbo) for 200
and while its been done, it hasnt been done to death.
rebuild w stock rings seals etc.
probably less money than an SR (and if not at least i can upgrade gradually after the longblock is assembled)
evildky
06 Nissan 350Z GT
I know of 2 in a 240sx, one (srman) I sold the guy half the parts he paid some hack to wire in the stock harness and ecu, I fixed it for him, the other is pallnet on hybrid and I sold him the z31 electronic's to use ont he swap, so no it doessn't have to be MS, but if you want to use larger injecotors and turbo's it's a good idea!
and you need a maxima oil pan whihc I think I still have
hbpignosePA
90 Volvo 240 (sold)
cool stuff man your always so helpful.
yea i know about the maxima pan; and an r32 cross member.
probably wont start everything till march or so... just slowly gather the parts before i send it out to a machine shop.
kelloggman
Car: 73 240z
evildky wrote:if he's running megasquirt he can use cop, edis or an n/a distributor, megasquirt gives you infinite options
really thats cool
kelloggman
Car: 73 240z
what else can you run with na parts using megasquirt
evildky
06 Nissan 350Z GT
kelloggman wrote:what else can you run with na parts using megasquirt
not quite sure what you're asking but megasquirt is open source and a very flexible format with built in extra IO ports for truely unlimited customization, yoiu can run knck sensors, electronic boost control, control electric fans,, run open loop, closed loop it practically tunes itself with a wideband
Return to “Datsun Z Forum”
