DuckyD wrote:
As far as FPR, industry standard is pretty much the Aeromotive A1000-6.
That being said, I am glad that you are adding up this build but I have seen a lot of these on NICOClub, and it always end up being some kid with dreams scribbled in crayon. Just saying.
Ok I will check into that FPR thank you. Yes I know a lot of people plan a build and really they are only just dreaming. I am not super rich and no I'm not going to go buy all this tomorrow and pay someone to slap it on. I get on average about 2500 a month that I can spend on whatever I want. Some has gone into savings, some is furnishing my condo I just bought. This part right here is only for the build of the engine. I have already bought a bunch of stuff for this car.
Silvia Front End
Rota P45r's(cheap and needed for 5 lug quick and cheap)
5 lug swap ichiba fronts oem z32 rears
Z32 30mm front calipers and rear calipers
ss brake lines
Z32 Brembo Rotors
SR20DET OEM Gasket Set(thought I was only putting stock motor in at first)
Stance GR+ Pro Coilovers
SPL Rear control Arms
SPL Inner and outer tie rods
SPL Toe Rods
SR20DET Redtop Motor Set
Z32 E-brake lines
Z32 Shoes
Projet Mu Brake Pads all around for Z32
SS Clutch Line
Excedy Stage 2 Clutch kit(need to sell)
SR20 Radiator
I'm sure there is other stuff I'm missing. I'm not at home with all my lists. Yes this build will take time but I have a 94 Infiniti J30 for daily driving so my car can be down for a few months while I gather money and parts.
