Building a KA24DET, need help
Joesph R Cooper
Ok,
so I would rather build my KA than swap an SR. Question is, how much will it cost me? I'm looking to re-build it(it's got 208k on it) and put a reliable turbo kit into it. Can anyone offer advice/point me in the right direction?
jeff420
Car: too many to fathom
add up the cost of all the parts then call a machine shop and ask how much their machine work is going to be.
lrb_2000
Car: '91 Nissan KA-T hatch
Final cost, engine build + full turbo kit and tuning.. probably at least $5000
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
i'm getting my motor built w/ arias(.020" over), eagle rod, acl main/rod bearing, arp main/head studs, felpro full gasket set, osk timing chain kit, and Briancrower stage2 camshafts for about $1670 in parts. Paying $1100 for full built, including bore, honed, hot tanked, checked for cracks, painted, installing all the parts, 5 angle intake valve job and 7 angle for exhaust, everything taken apart and cleaned.
for a grand total of about $2770, OMG i just realized how much money i thrown into the engine . my whole t25 turbo kit cost me $3k+ since i went all out with name brand parts.
DevilMB3017
You have to do it in stages, IMO.
You have a clear goal, and you have to set up a plan.
My plan was rebuild the motor, and break it in. While breaking it, I saved for my turbo kit parts. I bought the turbo parts and as I was breaking that in, I saved for wheels/tires. Then I saved for brakes. Next is cooling, seats, a cage, etc.
It works out much better for you if you have a clear plan and try to stick to it, but remember that life happens. You might need some money for something else or you might have something in your car break.
FYI, after rebuilding my motor, installing a turbo, wheels, tires, suspension, and other odds and ends I've cracked about $11K. It adds up quick. I however did not cheap out on anything really...
kouki_hmongster
Car: Want 97 kouki
having a car as a hobby is really expensive, but pays off in the end.
NizzmoS13
Car: 240sx
Currently am doin a rebuild on my motor. For Arias .20 over pistons, AMS/Turbo240 Sportsman Series Rods, Clevite Main and Rod Bearings, Fel-pro Full Engine Gasket Set, Arp Main/Head Studs, New timing set, New OEM oil pump, and Crower Stage 2 Cams all for around $1800. Then the motor was hot tanked, bored, honed, and resurfaced for $200. So $2000 in parts but am putting together myself so that should save me some money. Jeez am droppin alot of money .
DRIFTING.com
Joesph R Cooper wrote:Ok,
you can use our SR20DET Motor Build parts list as a "rough" referencehttp://store.driftingshop.com/srmobudvdo15.html
Stock Forged Steel Crank micropolished, balanced, and cleanedWPC Treated 87mm CP Pistons and PinsEagle Forged Connecting Rod w/ ARP 2000 BoltsNPR Stainless rings WPC TreatedACL Race Main, Rod, and Thrust BearingsARP Head and Main studsCometic .040 MLS Head GasketStock Head 3 angle valve JobJUN 272 11.5mm CamshaftsGReddy Adjustable Cam SprocketsPeak Performance Valve Springs and Titanium RetainersPeak Performance Bronze Valve GuidesPeak Performance Rocker Arm StoppersOEM Nissan SR20DET Gasket SetOEM Nissan Front Cover and Oil PumpOEM Nissan Timing ChainOEM Nissan Revised Timing Chain GuidesOEM Nissan Water PumpGreddy Aluminum Oil Pan
achillies0701
Car: nissan 240sx (s13)
im starting out too, i wanna build my heaD FOR TURBO, I KNOW THAT I WILL COST, BUT THING IS I WANNA KEEP MY KA, I KNOW A LITTLE ABOUT MOTORS BUT NOT MUCH SO IM ASKING WHAT SHOULD I DO TO BUILD MY HEAD, SO FAR I GOT IT POPTED AND POLISHED, I HAVENT BORED IT YET CASUE i dont know if i can find an oversized vale big enough. i know i need retainers and springs cams and cam gears, if im missing anything can you let me know and if you have any sugestiong for, i would like to hear them, and please tell me the best thing i should get cause.thank you
