Building a CA18DET
zEy
Car: computers (hardware)
I wanted to rebuild a ca18det whenever I got it but then I starting thinking why not just build it from scratch I know I can use the pular's block or something like that. I remember talking to NeedCAforS13 about it. He give me a list of the parts I would need to get that's here in the us. Can't seem to find it anywhere, would anyone know what parts? If so post up a nice list of the stuff I would need to get. TIA
Did a search on building CA18DET and this is the closes thing I found to building a CA18DET from scratch but it's rebuilding not building from scratch.
http://www.nissaninfiniticlub....18det
redamnavit
I'm fairly sure none of the US-spec CA18DEs come with crank girdles. Not that its required, but it would be something you would have to source yourself if you wanted it.
nab911
Car: 93 Nissan 240SX SE
Get a ca18det block imported, sourced from somewhere here. Hell i think ca18det is selling his block. But then u can go junkyard hopping searching for pieces to go in.
float_6969
You won't have a crank girdle or piston oil squirters if you build the DE block. You'll also have to come up with all of the electrical and a transmission. Just get a motorset and rebuild it.
zEy
Yea that makes more sence I was just curious.
What would I replace when rebuilding the motorset and where would I be able to source the parts from?
Nismo1182
Car: Z06
88 Nissan Pulsar.
Would you be the first CA18DET in PR? Are there any swapped 240's over there, SR or CA?
redamnavit
float_6969 wrote:You won't have a crank girdle or piston oil squirters if you build the DE block. You'll also have to come up with all of the electrical and a transmission. Just get a motorset and rebuild it.
If you were going to do this from scratch you might want to consider, and figure in the cost of, going with a standalone system.
What do you plan to put this in?
zEy
I don't even remember seeing a 240sx in puerto rico let a lone a swapped one, but I use to live in pr. I live in nyc now. And I planning on putting it in a 93 coupe.
