Build your own sway bar?
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
aero1310
Car: 90 300zx with rb26 swap
Has anyone built their own swaybar? Or have some kind of knowledge in this?
Im doing a RB26 Swap in a 300zx, and according to what others say, the sway bar will hit the stock rb26 oil pan.
Im not paying 750$ for a custom one.
Anyways I got a piece of bent solid steel pipe from work. I was thinking about cutting a section out of the stock sway bar and welding the piece I got from work in there. I think it would hold up for daily driving usage, but not sure about how well it would hold up when I take it to the track, and don't care to find out after the car rolls over lol
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Plain steel isn't going to work, that will just bent and eventually break.
What you need for a sway bar is 4340(chromoly), which could be cut and welded, but is some times tricky to work with and must be re-heat treated after welding.
A sway bar is basically a spring.
maik21
Car: 90 Nissan 240SX Coupe 5.0
my swaybar was cut an re-welded with a mig welder and it works very fine. i do this because swaybar hits oilpan when i lift car for a wheel change.
it was about $25 usd
aero1310
how long have you had it like that? you drive it pretty hard, put alot of stress on it?
maik21
i dont drive hard on corners because im running a welded dif but i use it on street and drive in highway to at about 60mph. i drive in bumpy roads too.
Flipnirish
Car: 240 sx
You should look in to getting a sikky sway bar. Works perfect!
Return to “Hybrids”
