build top end for gt2871r?
boost_creep
Car: 92 sr powered coupe,06 Spec V
im pulling the head to do a metal head gasket,and wondering if i should upgrade and of my valvetrain for this setup.im taking it to a friends shop where he will port and polish,3 angle valve job and replace stem seals and put it all back together.im curious to know if i should give him new springs,reatainers, or any of that sort,or will the original parts be sufficient.i looked into the hks cams and springs,but it says only stage 2 u need cams,and thats 400+.im not goin past that,so im kinda stuck in the water.any help?
boost_creep
bump...i was thinking about maybe just replacing the springs with new oem ones.but i cant find them anywhere.then started looking into the greddy springs,but with a hks cam?anyone have this combo,or can someone direct me to oem springs.or should i just leave them and just get the cams?....someone help.
boost_creep
bump
TougeTune180
Car: 1991 Nissan RPS13
what lift/duration cams are you going to use? i would suggest that if you are raising lift, then you should get some aftermarket springs, toda makes some good titanium springs that are around 220 bucks for a set....also get yourself some rocker arm stoppers, i had friend float a valve with his sr and it tore everything to peices....so rocker arm stoppers and new valve springs will help stop valve float at high rpm...hope that helps
spider_slayer
Car: S14 240SX
S13 240SX
boost_creep
well,i was looking into the hks step 1, 256 cams,but it says valve springs recommended for stage two.so should i just stick with the stock ones?thanks
