92 240SX coupe build thread 350z swap
Razi
Car: Moo
Wow, I'd love a set of those rollcenter/steering quicker things!
donandal
Car: '92 Nissan 240SX
'08 Nissan 350Z
home-built roadster
flynbyu82 wrote:These are what I am running...
My ride height...
I am fairly sure that the springs rest beside the front wheel, I will have to check. I guess I could raise the lower spring perch then get a shorter spring, that sounds like a reasonable way to gain some inner clearence. I also have an old 350z crossmember with the rack and pinion attached. I see what you're talking about with the offset tie rod. I wonder if their is an otc tie rod that would work for the 240sx? No mill or lathe for me, I think that might be something beyond the capabilities of my bandsaw/drill press/welder that carried me through the rest of my project fabrication :)
Your front springs look fairly short, are they the 6" eibach springs?
yes we used 6"/400lb eibach springs ABOVE the tire. If you had to go beside the spring it adds quite a bit more.
We built the offset tie rod end to get enough clearance at full lock on the steering, but some of that NEEDED
clearance was because our tie rod end is lowered, and that puts it closer to the wheel rim also.
the clearance here at the strut tube is only about 3/8"
donandal
'08 Nissan 350Z
home-built roadster
almost forgot...
this is rear from straight down... all pics have no spacer
another from straight back
and side
all of these are with no roll/pull
Nostalgia_
Car: Pope-Mobile
whenever you have some spare time, a write-up on the 350z dash would be great. I would definitely do it. you don't see too many S-Chassis builds with one-off(and well done at that) fabrication due to the tremendous aftermarket support. makes me want to experiment.
donandal
'08 Nissan 350Z
home-built roadster
Nostalgia_ wrote:whenever you have some spare time, a write-up on the 350z dash would be great. I would definitely do it. you don't see too many S-Chassis builds with one-off(and well done at that) fabrication due to the tremendous aftermarket support. makes me want to experiment.
I'm keeping pics of all of the stuff, so when I get it organized and get some time
I'll get it posted
thanks
98blackbell
Car: 1995 Nissan 240SX SR20DET(STOLEN)
1993 Nissan 300ZX 2+2
2006 G35 Coupe
1998 Chevy Tahoe 2DR 5.7
1975 Datsun 260Z Turbo
Absolutely awesomely astonishing alarming amazing and astounded
Great JOB!
donandal
'08 Nissan 350Z
home-built roadster
My ride height...
You don't have PM enabled.
I'll check the spring perches and camber plates and get back to you
donandal
'08 Nissan 350Z
home-built roadster
here is a picture of the top perch
it was trimmed to the diameter of the springs after this picture
our top thrust bearing is inside this top collar
the offset shoulder puts the spring top pretty close to the camber plate
the gap at the top here, between the top of the collar and the bottom of the camber plate
is only about 1/8 inch at the worst case scenario while going thru steering travel
the bottom of the lower perch collar is trimmed at an angle to give extra clearance also.
this collar will be set to the bottom of the threads for our ride height.
when it's set this low, the tire clearance is about 3/8" beside the strut, and 1/2" at the beveled spot
on the collar
Hoffman5982
Car: '95 sr20det 240sx
My ride height...
Have you recently been in the Florida/Alabama area? I swear I saw that car on the back of a trailer being pulled by a red silverado i believe
Glen27007
Car: 1991 Nissan 240sx se
1996 Nissan 240sx base
really good build you should take some videos drifting i wanna see how she runs
flynbyu82
Hoffman5982 wrote:Have you recently been in the Florida/Alabama area? I swear I saw that car on the back of a trailer being pulled by a red silverado i believe
Haha, ya, SCCA in Dothan a couple of weekends ago or Moultrie last month and last weekend. If you saw me on 319, it was Moultrie, I-10 or 231, was Dothan :)
O, I guess no PM? Enabled now, sorry, I was trying not to keep cluttering you're thread :) I greatly appreciate you answering all my questions. You have definitely have given me ideas to run with...
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Nice VQ35HR I really want one.
deletedalien
Car: Nissan S13 89 VQ35de
Came to THIS thread looking for pic WTF man! hahaha
