Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Thu Oct 03, 2002 4:27 am
my reverse quit on me last night... worked all day fine, came out of my last class at around 8:15 at night, switched it into reverse, and it acts like it is in nuetral, this is an automatic by the way.
my car has almost 160K on it now, its a 95...incase any of you guys own a auto 240, ill see if i can explain what it felt like before this happened. in the mornings the transmission acted real funny, it wouldnt downshift easily, then when i put down the gas more to get it shift, it would go down into first (if i wasnt going to fast) and rev way up...then when i try to brake it also wouldnt downshift and i had trouble braking normally. when the car was warmed up, it would hang on gears a little as it shifted up if i wasnt at WOT. and it hesitated to downshift a little.
my forward gears still work, a friend of mine took out the dipstick for the transmission and smelled it, told me my transmission was burnt and the forward gears are soon to go. i smelled it, it smelled something like hot rubber. (the dip stick was behind the intake manifold...took me forever to find)
anyway, i am kinda wondering now what i should do...i mean if i can get another auto transmission for cheap i might as well do that. but, if i can make it a 5 speed for not to much more, i plan on doing that. any opinions? thanks.
