Buggered DiF fan controller?
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
I have everything hooked up correctly and im trying to run an s14 fan on it. The fan works fine when hooked up to the battery directly.
When i put it into program mode i cannot get the fan to "pulse" like its supposed to. I have also checked this on a multimeter. I cannot get any activity out of this controller at all. Ive tried reversing the coolant temp sensor wires and nothing
I have continuity between the fan1+/fan2+ and the block which doesnt seem right. Seems like a blown circuit/bad unit.
Anyone?
greencar
Car: 1992 240sx se
is the ignition on when you do this? For me, I had to have the key on for the fans to pulse, it worked fine after that
ST240
Yes. Ive tried that as well.
