pr240sx »
https://forums.nicoclub.com/pr240sx-u5499.html
Tue Oct 18, 2005 6:31 am
You can get yourself a DIY kit if and only if you buy with patience.I setup my kit basically in 2 years!!, spent only a little more than that.Have a range of prices instead of a fixed one. LikeTurbo 120~150 good used one, be ready to rebuild it just in case.Manifold No more than 250 and have a solder or a friend who can solder ready, just in caseFuel pump no more than 100 shipped for this. Have several choices, Z32 or Walbro. i have heard that newer Supras work too but dont really know.Intercooler. Tru using a SR setup, that way, you will save on piping and a BOV. I will pay no more than 150 for a perfect core and pipes. If you have an intake, you can modify it to use it as a cold pipe.Exhaust Go to your muffler shop. I made mine, no name exhaust and spent no more than 200, including downpipeSR injectors (370) no more than 100 for a set, cheaper and safer than your stock ones. you can get some cash back by selling the stockers to Deathwordks (whatever!!) guy.SAFC used one for 150 or less, these things great for no more than 8 psi.ortuned ECU. Using a tuned ECU will setback your budget quite a bit. But it will pay for is plug and play. Get a used one. Shop safely. Pay no more than 300 for a chipped ECU or better yet, get a stock ECU and chipped yourself!!Clutch, you gan replace this later on the build, if needed. There is several options here. The cost is your limiting factor here.Oil pressure kit. Biuld yourself one or go to Ebay. Also, truck auto parts carry SS braided lines for cheap!!Drain, up to you, I plan to use a kit. Includes bung and drain hose. The IAT kit is good but expensive. You can use a drain kit for automatic transmission available everywhere. Way cheaper!!Couplings, use the one that the SR pipes uses or, use rubber couplings from the hardware store. At least you can check how much you need. These couples WILL NOT LAST!!! Also check the truck auto parts for these. way cheaper than those silicone overpriced ones. Get the clamps for them too!!Get you parts carefully, read, search,ask and learn.Depending on how much you want to DIY your kit the cheaper will be.
There is a list member that post the following "Cheap-Reliable-Fast, you can pick only 2"
