budget sr20det vvl build (sorta)
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Stay tuned, ill be photo bombing this build thread. Image
the beginning
How she is now running ( some slight differences)
unfortunately this is the only pic of the currently built engine. Sleeves pistons, Rods, cams, solid lifters, Springs, etc.
compactfean
daily
cwest bumper and hood 5 lug conversion and some Chrome z's and hours of sanding and primer.
compactfean
daily
new wheels came in
Much better!
compactfean
daily
My "new" seats before and after
compactfean
daily
Got all my diff goodies!!!
Tt axle with q45 diff axle and hubs with some extended wheel studs pressed in.
compactfean
daily
Let the fun begin!!!
4.08 ring gear with q45 guts
shims I had to make with a tubing Cutter to fill the gap from the s13 ring gear bolt to the q45 vlsd assembly.
all put back b together
compactfean
daily
A good comparison of the Monster axle upgrade!
compactfean
daily
Let this mother f*** burn! ;) lol. Even if you can get them out without burning them (which of they are bag enough, you can) its still fun lighting stuff on fire!
Diff axles hubs subframe bushings all done
compactfean
daily
My uprights (I actually used my s13 drop Springs instead)
the last of the poly urethane bushings!! The best day of my life! Lol
Uprights all done up.
tuckin slicks!!! Lol Image
compactfean
daily
Power = broken transmission. ... By By sr helloooo vg!
compactfean
daily
Bell housing off to machine shop
everything test fitted!!!
compactfean
daily
My baller fan controller! Lol
this is how I wired it up (stole this from moso on here a while back)
if your going to copy this don't get the fan switch from napa. Mine and mosos switch went bad within a year. I'm running a fan switch from orrielly made by import direct which is basically genuine Honda.
Also I did away with the emergency switch, and ran the power wire that goes through the relay to the fan switch from the 10a fuel pump wire and just grounded the other wire from the switch straight to ground. The way it is in the diagram would make the relay buzz sometimes.
compactfean
daily
Some nicks and nacks
Sold my baller apexi bc for this
it actually works better than ebc!!
compactfean
daily
Twisted motion bov welded on
hooked up to my ported throttle body and intake manifold.
It was actually quite a task to get this thing to pass a boost leak test and function properly with my car being maf, inevitably I ended up running this one super tight, and my ssqv on the other side.
compactfean
daily
trying to solve the infamous catch can filling up problem. This actually works but I will be eliminating the stock catch can to clean things up by running the line straight into the vc with an a/n fitting and stainless line.
compactfean
daily
Time for stacking parts for vvl monster
Christmas for myself!!!
compactfean
daily
Match made in tuner heaven! Fic flow matched 1650cc injectors with aem peak and hold driver (any ecu I will use doesn't support low impedance and didn't want to run resistors, this will make it more drivable anyways)
compactfean
daily
some port work before ceramic coating
compactfean
daily
short ram intake? I think yes! ;)
Hijacker
Car: '92 240sx Convertible
'94 F-150
Looks very good so far! Keep the hits coming. I take it you used urethane bushings for the Z uprights?
compactfean
daily
Yeah I took the urethane bushings out of my old knuckles and used them in the uprights. The uprights are wider so had to cut them in half but worked just fine. These uprights came from a q45 that had hicas so that had to be pressed out and bushing halves went in no problem.
compactfean
daily
pita
cut off the runners and hat for future porting
vvl head!
compactfean
daily
Btw if anyone Comes across some sr16 cams lmk. The cams in this engine were rusted so im on the hunt.
compactfean
daily
HUGE BRAKETHROUGH!!!
nobody makes a vvl top feed fuel rail but this will fit with only 2 custom brackets!
manifold sort of mocked up, no clearance issues.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
All looks good to me... But so far I'm not seeing anything remotely "budget". :gapteeth:
compactfean
daily
Lol I knew that was coming. Most of the other stuff I already had and was going to build the sr with anyways. "Budget" comes to play how I will do the head and head only.
So far in the head swap I'm $80 into it.
compactfean
daily
$100 if you count my Harbor freight air saw. Lol
Seishuku
I wish I could find a VVL head for a good price, but everyone knows that they can charge big bucks for it...
One of these days I'll do this swap too, always been one of those things I want.
But then again, I'm gonna need a stronger trans and rear end first... :eek:
compactfean
daily
Diff should handle the power. Trans is usually first to go. My trans only lasted 2 months at 25 psi on my gt3071rwg . I could have got another stock trans but with my future goals I found pointless.
Seishuku
My s12 has an r180... its welded, but it still won't take much to break something.
Actually I'm more worried about axles.
I've already popped 3rd gear on my original w71c, now I'm on a lower mile s13 box but its just a matter of time.
