the_garynator »
https://forums.nicoclub.com/the-garynator-u30732.html
Mon Nov 08, 2010 8:17 pm
for an rb30DET you cannot use the rb20 bottom end. You're going to need to source an RB30 bottom end which would need to be imported from Austrailia. they are super cheap there but due to importing and a large markup, it's not cheap.
Also, it would be cheaper to get a RB26 head and make it work vs getting an RB20 head to work (not even sure it is possible, i've heard it is but haven't seen any that have actually been built).
as far as a turbo, like TJCars2 said, it'd be cheaper to buy a better one than get yours rebuilt.
Also, the GTR turbos are smaller than the stock rb20 turbo. If you're thinking about using rb26 twin turbos on an RB30, you would need to source both stock twins from an rb26 because the rb20 is a completely different turbo.
Either way, there is no "cheap" way of building an RB30DET. Your best bet is going some other route.
Don't mean to burst your bubble, but it's just the way it is.
-Gary
