Nissan2367 »
https://forums.nicoclub.com/nissan2367-u118618.html
Thu Feb 05, 2009 1:44 pm
I agree with ^. The little stuff is where it hurts! I didnt see anything in there for gauges ie: wide band, oil press, water temp, and fuel pressalso dont forget a thermostate. also a seperate one from Flex-a-lite to turn your fans on and off. I know cx-racing has a fan, rad, and hose kit for somewhat cheap.Also you will need an air filter for your maf, I went with apexi thats 80-100 alone.I would stick with the greddy timing belt, its one less thing you will have to pay twice for in the futureDitch the oil pump you wont need it. thats an extra 300!Adjustable fuel pres reg too, and if you are using the stock rail you will need the NISMO adapter for an external reg. I dont think you can really do a clean quality swap for under 5-6k I know mine i just hit 8.5k but i have had alot of problems and i buy all name brand parts when i think one is broken.Good luck man! My budget with the car was 8k and i just hit 11k!
