nsrZ32 »
https://forums.nicoclub.com/nsrz32-u20984.html
Mon Nov 21, 2005 3:48 pm
I've been looking into stepping up the braking power on my 300zx and have found a lot of appealing big brake kits (stoptech, AP, Endless, etc) but they are insanely expensive and none of them would fit with my current wheels as you need 18" rims to fit most of them.
So I got looking into the big rotor type kits since the stock 30mm 4pot 300zx calipers are excellent. Now there are quite a few rotors out there that are 30mm and caliper relocation kits for them (VR4 12.5", 350Z track 12.8", cobra mustang 13", skyline gtr). Stock 300ZX brake rotors are 11".
Now here's the thinking on the bigger rotor idea....Larger brake rotors, even with stock calipers, can provide a significant improvement in braking over stock rotors. The larger diameter moves the caliper further from the center of the hub, which gives the caliper more leverage thus increasing brake torque (with the same pedal pressure and pad friction). The larger rotors also have more thermal mass, which reduces brake fade.
Here's a picture of a 350Z track model rotor vs. a stock 300ZX TT rotor for comparison....
And here's a picture of the VR4 rotors with the caliper relocation brackets...
So for a definate upgrade and for under $600....what do you guys think?
