Well, I started it this morning after plugging the z32 MAFS, and it ran just like normal, so I assumed the MAFS was th eproblem, but just lik eusual, after about 5-10 minutes of driving, it lost all power and started bucking under throttle.
This rules out the MAFS and a wiring problem, too, seeing as how it is so consistent. I smell fuel in all cylinders, so the injectors are okay.
My only real idea is a boost leak that only happens when everything gets really hot and the pipes and connectors expand.
I'll try the carb cleaner thing on the pipes and see what happens. The rocker arms look good as do the spark plugs.
