wasaekhan »
https://forums.nicoclub.com/wasaekhan-u131647.html
Tue Oct 13, 2009 2:29 pm
alrite so my car is at the shop with a freshly swaped s13 blacktop into and s14...the car is idleing perfect, however, when mashing into the throttle it bucks and the cluster cuts off... it starts rite up somtimes but yet other times it clickes a few times before firing rite up. the tps censor is fine the cas is calibrated it has a walbro fuel pump and the coil packs check in...also when it starts the engine heat in the cluster shoots up to a little over half way to max heat, even though its a cold start up... id appreciate your input thanks!!
