iimagiin »
https://forums.nicoclub.com/iimagiin-u126024.html
Sun Feb 15, 2009 7:24 pm
last time i set timing it was at 20btdc..i actually backed it off from that thinking it was firing too early every once in a while. i do have new wires, plugs, and cap. i have two working distributors(i say they are working) the problem exists with both.i recently (within 2000 miles) rebuilt the motor. have not felt a need to check compression since initial install and all checked well then. guess it wouldnt hurt to check it again. i took a drive today at highway speed (75-90) around 80ish it would cut every so often. but its not as noticeble as when it cuts at 4k in lower gears...just a slight "stumble". before i rebuilt the motor the vehicle had sat for 3yrs in my possession. when i first dropped the motor in i had to blast **** out of the fuel lines...im starting to wonder if possibly they arent fully clear. perhaps my injectors arent getting the gas they need. then my other thought is that i might have an injector clogged. ill check tps again, although when first setting timing and everything it checked good. i did run into a problem with a maf. a few months back but the symptoms were completely dif. ie. engine hitting rev. limit at 3k.the car pulls hard, idles smooth, and burns zero oil. thanks for all suggestions, ill be looking into them all...never hurts to double check..thanks again
