turbonola »
https://forums.nicoclub.com/turbonola-u34370.html
Sat Oct 11, 2008 1:00 pm
a small excerpt from that link.
"Vapor reducing structure (25) is constructed and arranged to be associated with a fuel pressure regulator (18) of a fuel system (10') of a vehicle. The pressure regulator has an outlet (28) for fuel that is in excess of fuel required by an engine of the vehicle. The reducing structure includes a fuel accumulator (26) associated with an outlet of the pressure regulator defining a volume in which fuel exiting the outlet of the regulator can accumulate. Flow restricting structure (30') is associated with the accumulator and is constructed and arranged to create sufficient back-pressure to eliminate vaporization of the fuel exiting the outlet of the pressure regulator." "In some of today's automotive applications, higher flow rate fuel pumps are necessary to keep up with increased engine demand at wide open throttle. A typical mechanically regulated system uses a fuel regulator to deliver the exact amount of fuel necessary to the engine, and returns the unused fuel back to the fuel module. When that same vehicle is running at idle, nearly all of the fuel output from the fuel pump is directed through the pressure regulator. Due to the design of the regulator, the fuel is sheared as it passes through the regulator, vaporizing the fuel and creating small bubbles. This shearing of the fuel and generation of bubbles in turn causes an audible noise to be generated from the pressure regulator. This noise is often audible inside the passenger compartment and is undesirable to the customer. "
