BTM Issue - Code 21 Loss of IG Signal
Edub1
Car: 89 240sx KA-T
Car starts, runs horribly, backfires and will not idle. ECU gives code 21 - No IG refference pulse, loss of primary signal.
BTM 5462 wiring - the one everyone is using on the SOHC.
Red, Ts into red/blackOrange -> coil - (gr/blk)White -> harness (gr/blk)Black to ground
One post here said something about a tach convertor part 8910. Does anybody know anything about this? Is there something I'm missing?
KATwo40
Car: 1993 240sx KA-T
I spoke with the fella at MSD once about needing a tach converter on our cars and he swore up and down that none was needed.
However, EVERYONE on this forum and FA said that it was a must and wouldn't work without it.
Edub1
Car: 89 240sx KA-T
Wouldn't work as in tach won't work or as in doesn't run worth a damn?
KATwo40
As in doesn't run.
Edub1
Car: 89 240sx KA-T
Called MSD, they siad I need the tach adapter.
KATwo40
^^^ Figures, I must have had the one guy that mis-read the tech notes on our cars. LOL
Glad you figured it out quickly!
WDRacing
Yeah, atleast you know the fix...well hopefully its a fix..lol.
