Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Wed Dec 03, 2003 8:52 pm
Verify, that the unit will switch between defrost, vent, floor/vent, and floor. If it does this fine, but just blows cold air, unless it is set to 85 degrees, it could be your plenum temp sensor. That is what the dealership had to replace in my wife's 2000 I30t.
The A/C worked fine, and all the dampers moved fine, but the system would not allow hot water into the heater coil, unless the setting was on 85 degrees. I could set it at 84, and the air would start to get cool again.
I don't know if this is the same problem, but it might be worth a check.
Definitely get the servcie manual and the TSB's. I don't have them, and am at the mercy of those that do. Begging usually works.
