broken wheel studs
StricNyne
Wow, while drivin home i broke three wheel studs because someone sabotaged my car, and loosened 3 of my lugs, ne way how do i fix this ? are studs threaded into the bubs, or are they pressed ? should i just replace hub ? ne help is welcomed
mss5413
Car: Nissan 240sx
They are very cheap and they just tap out of the wheel hub. Of course it is pulled in from the back of the hub so you tap toward the hub from the outside and it falls right out. Then you just push a new one in and it can be tightened when you put on the tire or just tap it back in with a ping hammer.
StricNyne
awesome your my hero !!!!
