Broken Water outlet Nissan 240sx 91 KA24DE, help please
vincentflagg
Car: Nissan 240sx 91 KA
HI all.
the water outlet of my car a nissan 240sx 91 KA24DE it just corrode away (rotten) cant find any replacement online or in any store, or even how to replace it. I try to remove it but is like solder in place. I need some help
Roger_cha
Car: 91 nissan 240sx
are you talking about the one on the intake manifold or the one on the block.
vincentflagg
Roger_cha wrote:are you talking about the one on the intake manifold or the one on the block.
is the one over the intake, the one that give water back to the radiator. it have a 3 way water outlet, it just rot away and cant take it out, its like fuse.
Roger_cha
ok then its the one that connects to the intake manifold then, well i havent have any problem with it or heard anyone having the same issue basically you cant take it out unless you cut it off. my advice is just change the top piece of the intake manifold with a good one.
