Its been this way since i had it and the receiving end(vacuum hose) has a screw inserted
ps. i tool the plug off for the photo
the reason i saw this in the 1st place is i was looking for the reason my heater wont heat up but thats another story
That is the evap control selenoid and what is happening i believe is the fuel vapor gasses are released into the engine compartment, probably not a good thing. What the ecu is reading is if the selonoid is opening and closing, so it doesn't monitor the gasses coming out of the selonoid going into the combustion chamber.Slumpert wrote:Looks like evap control selenoid. Periodically the ecu will tell that to open which allows gas vapors to be sucked from the canister into the intake.
Kudos to the previous owner for figuring out how to hide that from the ecu as you should be seeing a CEL.
