varn »
https://forums.nicoclub.com/varn-u12531.html
Fri Oct 08, 2004 2:52 am
When replacing the water pump on my 1978 280Z one of the larger bolts (8 mm) twisted off. It's the one below and to the right of the large rectangular water pump flow hole. This happened even though all the necessary precautions were taken like striking the bolt head with a drift and hammer prior to removal. And, trying to slightly tighten and loosen the bolt prior to trying to remove it.
Anyway it twisted off. Upon removal of all the necessary parts (timing case cover, oil pan, valve cover, distributor, etc.) it was discovered that this bolt is twisted off flush with the face of the block. So, it cannot be "grabbed" with a tool and twisted out.
So, for several days, I used the super duper rust disolver liquid spray to try and disolve the rust in the threads prior to using an easy out. It was soaked and soaked with this spray.
Next, I drilled a small centered pilot hole in the very center of the broken off bolt. Then, using this pilot hole as a guide, I drilled a larger hole in this broken off bolt. Next, I tried a small easy out. But, it did not budge the bolt. I was somewhat hesitant to twist with extreme force because I have broken off easy outs before and this only complicates the removal processes. Next, I drilled out the hole a little further and tried a larger easy out. Still no luck.
Maybe if I applied some heat to the area that would work?
My next step, is to drill out the bolt with a drill that is slightly smaller than the minor diameter of the threads so as not to remove much of the threads in the block. Then try and use a tap (same size as the existing threads) to remove what is remaining of the bolt. I have not gone to this next step yet.
Will this work or am I just wasting my time?
How are these bolts removed?
What about the metal shavings? Can these particles be flushed out since the whole front of the engine is now exposed and open?
