broken subframe bolt
blank
Car: buying
It sucks, but i can fix it. I am looking for pictures of the inside of the frame rail after i cut out the trunk. Plan is to pop the old one out and just make/get a bolt to replace it. I just dont want to start cutting until i know exactly what i need to cut. So yeah pictures or past experiences is needed!
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
There are only nuts and these thick plates that hold the subframe in. not sure what bolt you're telling about. Also s13?? S14?
danshaz82
compactfean wrote:There are only nuts and these thick plates that hold the subframe in. not sure what bolt you're telling about. Also s13?? S14?
i believe hes talking about the 4 studs that hang down from the chassis.
splintercell-massive-180-240sx-ca-jdm-p ... l#p6400441
Well im back once again with some updates. I caught hell with a broken/stripped subframe stud and had to operate.
1st- i had to remove back seat and use a 2" hole saw to gain access to stud.
2nd- soaked in pb blaster for a week until i could get some help.
3rd- i used a torch and heated the bolt head while my friend Danny from Sumospeed beat the s*** out of it with a sledge hammer from below... After 10 min it popped out.
4th- I scored a fresh stud and beat it back in place until it was seated.
