JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Tue Mar 25, 2003 6:20 pm
That is correct. You will need to remove the entire caliper and the mounting bracket. If you cant get a proper thread screw, try gently tapping on the rotor hat with a hammer as you pull. Once off, you can tap the broken stud out of the hub. I use loc-tite when i put the new stud in, just because i didnt the first time and it was loose and would spin when installing the lug nut. Tap the new stud in from behind (might require the brake dust shield, should be 3-4 phillips head screws) and then put everything back together. The final tightening of your lug nut should fully seat the new stud, and the loc-tite will keep it there!
