kansas240 »
https://forums.nicoclub.com/kansas240-u4822.html
Mon Jun 09, 2003 7:30 am
have you replaced your plug wires? i had 3 of mine cracked along the boot, so it cut out when the engine revved. path of least resistance. wrap them with electric tape, if it fixes it, you found the cut out. as for the speedo, if it is an occasional problem, check the connections and squirt in dielectric grease to keep dust away.
