You can use rocker arms from a FWD SR20, like from the old Sentra SE-R or G20. Thats what I am running in my DET head right now. I pulled them out of a G20 at a local wrecking yard. I also pulled all the valve shims, lash adjusters, and anything else I could get, cost me $5.turbo junkie wrote:I would like to get those arms from you if possible, I need four that I know of, and hopefully that will take care of it, also did you install a rocker arm stopper after you broke yours?
