MarkEmark wrote:That feed line looks really big because it's not a feed line. It's a drain line. Not sure where you could get an O-ring, maybe a hardware store.
Yea, I'm probably gonna end up getting another flange.
I had initially thought it was a drain line too, but if you look carefully (of course you can't because I didn't supply a picture), the an fittin on the other end is a -4 an, which hooks up to my feed line. I have a drain flange w/ a much larger hold & fits my -10 an line. Also, the flange doesn't hook up to the drain side (different bolt spacing) and vice versa. So I figured it had to be a feed line or a drain line that has been converted to a feed line.
Ah, stupid little parts I need to get.
Thanks for the wastegate info. Something really weird, to set it up initially, I will need to turn the turnbuckle (which of course broke as I tried to turn it - gotta get a new wastegate now) a certain amount before it will attach to the swing valve correctly & cover the exhaust hole. Now, I am guessing this will be the lowest boost I can run properly because if I decrease any more, then the swing valve will be partially open & I'm guessing boost will not build. Is it perfectly fine to keep turning the turnbuckle tighter? Will this break the wastegate rod or is that how it's suppose to work (since I've already broken 2 rods - stupid old parts, time for new parts)?
