Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Sun Oct 23, 2016 10:12 pm
Correct, that assembly is the LSV. The bracket hanging down connects to the back of the pumpkin on the axle. When there's a load in the cargo area of the vehicle, it pulls on the spring and valve, and it'll proportion the brakes for a little more rear bias. The mounting tabs for the bracket can probably be welded back on easily.
If you're not carrying cargo, it has little effect. My 2wd Frontier had it and it was noticeable when loaded. It didn't appear on later R50s; my 04 4wd doesn't have it. You could probably pull the spring and bracket off and not worry about it, but if you haul or tow things and can get it welded back on for cheap, may as well.
