jcquick »
https://forums.nicoclub.com/jcquick-u25031.html
Fri Aug 14, 2009 10:59 am
I installed a Greddy Oil Pan and when I looked inside the stock oil pan, I found this metal piece. Its approx. 3/4in. in length and 1/4in. in height. I'm pretty sure its a broken piece off the cylinder head. When I put my ear to the engine during idle, Its a little noisy on the exhaust side of the cylinder head. But, I've always had this noise ever since I bought the car. No problems for 3 years, even when driven hard. Let me know what do you guys think this broken part is? Will I have any problems in the future?
Since I was installing the Oil Pan and I installed an Oil Cooler a year ago, I wanted to monitor the Oil Pressure and Oil Temps. I've seen other guys install gauges in place of the vents, but I didn't want to lose the vents since I'm sweating my a** off during the summer. And, nobody makes a gauge pod for the glove compartment like EVO's or STI's. So, I decided to make a gauge pod out of fiberglass. It came out OK, but I need to learn how to work with Bondo a little better. I might lay some material (i.e. vinyl, carbon fiber, etc) down later to cover up the imperfections. I decided to use Autometer Mech. Carbon Fiber Gauges. The reason why Mechanical, they are way more responsive and accurate. I used steel braided line high strenght thread sealant so I wont get any leaks in the future. Let me know what you guys think. Thanks, JCDrivers Point of ViewPassenger Point of View
