FAST-DATSUN wrote:Please call me with the info!!! I would hope ANYONE with problems would call me ASAP so the problem could be fixed and/or could prevent any future problems. We can/will over night you new mounts that are correct for the swap. Please send me the bad mount so I can investigate the cause..If you want I will send a UPS will call tag for the mount.. What was your correction???? 619-449-4748
Mack, you're a good guy. Mckinney has treated me good when I purchased things from them and I dont want anyone on the forum to think I'm nockin your mounts.
Sorry I'v been so buisy lately getting my motor back together but I will send you the mounts and you can see for yourself what the problem is. If it were my choice for change I would change the threads of the mounts to a finer pitched thread because theres more strong bite involved I'v learned in my days of metric and standart thraeads. For me the finer threads could hold a lot more torque. But again its just a suggestion.
Just for feedback I would vote for stiffer polyurathane because the rb's are such a tight fit when you go mountain passing the engine tends to rub when you get motor mount flex. Plus I wouldnt worry about engine vibration because the rb's have such a tiny stroke compared to other motors even super stiff mounts won't send much vibration through the car.
