Qgrappler »
https://forums.nicoclub.com/qgrappler-u270.html
Wed Jul 30, 2003 6:45 am
I just receeved the replacement lug-studs from Scottsdale, and now I think I understand Gartors advice. The lug has a circular head, and a region just below the head before the threads begin which it "fluted" or grooved, in the direction of the long axis of the bolt.
If I get it right, Gator is suggesting that if you hammer the broken stub out, you can then insert the new stud from behind, and using a combination of a lug nut, a wrench and a "Spacer" to pull against, "pull" the stud into position and get it seated properly. I think I'll try that one.
The only issue seem to me to be whether I can get the new one started through the hub without removing it--"clearance" issue. We'll see soon.
Thanks
