Broken key in door
ecbach82
Car: 89 240sx ka24det
new account. been reading through this forum for awhile. you guys are good.
so anyways. my key broke in the handle and its out of reach of needle nosed pliers and such. any way of getting it with doing permanent damage or am i better off replacing it?
thanks in advance.
speedracermage
Car: 1989 nissan 240sx
pull off inner panel and order replacement door handle or lock assembly. i have the same problem on my car.
Firewind
Car: 240SX
Ummm... Lock smiths can usually get a key out in less then an hour. May want to give one a call, cost you about 100 bucks.
s13_chris
Car: 90 240sx Hatch
A. Lock smith and ask for a quote
B. Junk yard and ask if they have key for the car still
C. Take a door lock from junk 240 and ask locksmith to redrill.
Patarach
Car: 240sx convertible KA-T
I'm pretty sure you guys are thinking to hard here, try glue and a toothpick.thats what i did
H8tred
240sx_ch08 wrote:A. Lock smith and ask for a quote
B. I've never seen a complete lock set at any junkyard.
C. The term is called re-pinned.
I would just pull the door panel as stated above, unless you're not that confident in yourself. The glue on a toothpick will work, but let the glue set up for a minute as to avoid it seeping down into the pins ruining that cylinder.
ecbach82
thanks guys
s13_240_rb20
Car: 1990 240sx RB20DET
you miiigggghhhtt be able to do this with the lock still in the door, but it isn't too hard to go ahead and take it out for this procedure.
you can use a paperclip (or 2) to push the broken key back out from the INSIDE of the lock. Sometimes it takes a LOT of tries before you can get it pushed all the way out where you can grab it with pliers.
Obviously, you have to remove the door panel and roll the window up to get to the inside of the lock. I highly recommend removing the lock because you have a better "feel" for pushing it back out when you are not bending your arm 4 ways just to barely get the paperclip in the lock.
--TJ
H8tred
s13_240_rb20 wrote:you miiigggghhhtt be able to do this with the lock still in the door, but it isn't too hard to go ahead and take it out for this procedure.
--TJ
Actually the back of the cylinder is closed.
