Broken Injector pintle cover.
xs04298
Car: 1989 240SX Hatch/1991 240sx SE hatch
1989 240sx ka24eWell i got myself into trouble again...
I was trying to replace the o rings on my newly rebuilt injectors, and i forgot to put lube on the last one so it leaked when i was done (but it ran spectacularly, like a whole new car) so im tearin it apart to fix the last one, and somehow i managed to snap this little brown peice of plastic down at the bottom where the bottom o ring hangs on there. Does anyone possibly know where i could find this little plastic peice? i tried to pull some off the old ones but they were so fragile they snaped when i tried to get em off :mad
In shortDoes anyone know where or if I can find the brown plastic peice on the bottom of the injector? thanks
Thank you very much! :
navysnail
it sould be ok without it. just make sure you get all the little pieces of plastic out of there.
xs04298
Unfortunatly the bottom o ring fits around that, so now the o ring would be very loose around the injector without it
navysnail
the o ring is at the top, the plastic cover on yours appears broken only towards the bottom.
xs04298
It has a crack in it up in that area, but it seems to be fairly snug around there, is there much pressure in that area that it would leak? guess the only way to find out is to try haha.
Ive been looking EvErYwHeRe, i cant find that part for the injector, or even a rebuild kit or somthin.. :\
574-240sx
Car: Nissans, Toyotas, Subaru
In the long run it would be a good idea to replace it. You can find a set of SOHC injectors for $20 + shipping, just post a want to buy (WTB) add in the classified section.
xs04298
Probably so...wonder if anyone is selling just one, the other 3 are freshly refurbished, no sense throwing them out
Thanks though..
Those have to be pressed on... once they get brittle, they're impossible to replace.
Contact our sponsor, Deatschwerks - They can hook you up.
navysnail
i replaced all of my injectors a while back, i still have them though. I will check them to see if i have one that is still fine.
xs04298
Thanks!, but ive got a pretty new one someone else is sending me
i'll keep that in mind, who knows how many i'll manage to break putting in the new one haha, although now i've got bigger motor problems, think somthing with my EGR valve gone crazy, i dunno, this car has given me more headaches haha
